Ati Radeon 9800 Big Problems
deanmcdonnell
Hi All Im Not Very Good With Pc's Ill Be Honest, So Thats Why Im Here
I Need Help...Big Time
Well When I Start Up My Pc It Runs Fine Untill I Get To The Login Screen And 4 Lines Appear Down Screen So Then As Always I Restart The Pc And The Lines Or Dots Appear Erlier Than before, but when i get to the login screen they dissapper and the pc runs fine and then i play my game (world of warcraft) and it works fine for say 4-5-6 hours and then BAM! lines lag blurred screen you name it, and the same thing happens over and over and over, ive reinstalled graphic drivers and done Dxdiag tests and all are fine but the same thing happens, anyone know what the problem is?
this maybe unrelated but in december last year my power supply blew, the power supply was alot more powerful not sure by how much to my current one though, could that be part of the problem? i have 2 photos of these lines in action if anyone wants em my email is deanobhoyno1@hotmail.co.uk
Thanks 😱
I'm not exactly sure what you mean, but your graphics card may be overheating. Get a compressed air can and clean out all of the dust around your graphics card fan, as well as the rest of your computer case.
Well it almost sounds as if 1. als bluzman said your GPU is overheating or 2. your GPUs memory is bad.
The 9800 is a pretty old card. Came out in 2003. If it is just overheating you can try to blow the dust out and see if it does help.
To monitor the temperatures, google GPU-Z and download it. Should give you the temp under the Sensors tab. After blowing out the dust try seeing what the temps are on boot and then when playing WoW. If they go above, I would say 80c then its still getting too hot.
Another great tool for testing is ATITools. It can run a test for artifacts. Oh and before I forget, try turning the settings in the monitor down to 16bit. If the lines and blur goes away then that would mean bad video memory.
Hope this helps.
Hi There Again, Any Idea The Ideal Temp It Should Be At? When I'm Running The Net Alone It Says : PCB Temp 47-48.C and the GCU Temp 53.6c, is that too warm?
