ATi Radeon HD 4550 graphics card - Does it fit into an x8 PCI Express slot?
3D08
18
I am going to buy a ATi Radeon HD 4550 Graphics Card, I need to know whether it will fit into a PCI Express slot x8 or possibly a PCI express slot x4
If the slots are physically 8x and 4x in size then no. If they are 16x in size and just run at 8x or 4x speeds then they will fit. Whats the make and model of the motherboard?
The motherboard make is: Intel SE7520BD2 Motherboard
Thank you for your answer. Could you recommend a low profile graphics card for a PCI X8 slot? Just for some mild gaming?
