Hello to everyone
I have Radeon hd 5770 and the problem is that its all 3 outputs 2dvi and 1 hdmi Is broken.
At first there was no signal on 1dvi and hdmi, so I connected my monitor to the second dvi and made it primary in windows and like that the problem was solved for me for 3 months. Until now!!!!!!! Now the second dvi is also broken (maybe) and dose not give signal to monitor!!!!! I don't know where is a problem...
Also need to know that card is clean from dust I cleaned it and there is no problems with over hit. Also my monitor is vga and I connect it with adaptor to dvi.
So if someone has any brilliant ideas how to solve problem without throwing this card to garbage, pleas share it 🙂
If this helps, I was rendering in 3d max when the card started failing and then monitor said no signal!!!
