So basically I bought this new power supply because I'm planning on getting a new gpu soon. So once I got the new psu I went to install it and I double checked in plugged everthing right and when I went to go power up the PC nothing happened just a single click coming from the psu.
After 30 minutes of searching the internet and messing with my PC I found out that when I disconnect the atx/(cpu) cable everthing turns on but only for a second not sure why it's only that cable. The psu works just fine intill I plug in the atx cable.
Can someone help me out? I'm stumped.
My PC specs-
PSU(new): EVGA SuperNOVA 850 P2 80+ PLATINUM, 850W ECO Mode Fully Modular
PSU (old): Rosewill ATX 12V 650-Watt 80 PLUS BRONZE Certified Power Supply
CPU: Intel Core i7-4790
MB: Gigabyte GA-Z87X-UD5H Z87 LGA 1150 2-Way SLI Dual LAN ATX Motherboard
GPU: EVGA GeForce GTX 660ti SUPERCLOCKED 2048MB
RAM: Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz DDR3.
My PC specs-
