[SOLVED] ATX Case for about $50
edzor
23
I made a post here a couple of months ago asking the same question, and I want to ask again now just to see if anything has changed. I'm looking for an ATX Case that would give me plenty of room to build and upgrade in. Currently, I'm using a Coolermaster haf 912. I'm trying to avoid hitting the H500 price range mainly because right now, during quarantine, I don't have the same kind of budget. If anyone has recommendations for a good case, please leave them below.
NZXT H510 is now around $69, if you really do desire such a case. Cooler height is a huge factor, too. If you are using the stock AMD cooler, you are fine, but tower coolers can cause you issues, and may not fit.
https://pcpartpicker.com/product/6Cyqqs/nzxt-h510-atx-mid-tower-case-ca-h510b-w1
These are closer to the $50 mark. Options are a bit limited, right now.
https://pcpartpicker.com/product/HnDzK8/riotoro-cr480-atx-mid-tower-case-cr480
https://pcpartpicker.com/product/vYp323/cougar-mx330-atx-mid-tower-case-mx330
Your best bet is to put your build together, using PCPP, and then choose the case that meets your budget, and tastes.
I was recommended the MX330 in my original post. The only thing I really dislike about it is the honeycomb front, but other than that it looks like a solid case. The CR480 imo just looks like an awkward shape. I'll definitely keep the MX330 in mind since there's barely any options available right now.
