[SOLVED] ATX Case Recommendation
edzor
23
Currently, I am using an old Coolermaster HAF 912, and I'm looking at some point to upgrade to something new. I'm in the United States so I can easily get something from Amazon, Newegg, or the manufacturer's site.
I'd like something that can support 140mm fans but 120mm is fine. Tempered glass really isn't a requirement as I don't have a lot of RGB in my computer and really don't intend to spend extra money for RGB. I'm still deciding whether I want to set my computer on the ground or on my desk. I would most likely have it in a cart or something to raise it off the ground if I couldn't put it on my desk.
I had been looking into an NZXT H510 but I feel it's a waste of money for the tempered glass. What's a good recommendation for an ATX case that I could use?
Honestly, once you go much below H510 pricepoint (~$70), you start cutting corners.
You might not want/need TG etc, which is fine.... but go too cheap in price, and you get real cheap in terms of build quality.
Heck, some of the super cheap ($50 +/-) have internals that are not too dissimilar to the HAF912!
Cougar's MX330 ($46) is decent for the money. Still gives you a clear side panel, although acrylic I believe - but limited to 120mm fan support (x6 max)
https://pcpartpicker.com/product/vYp323/cougar-mx330-atx-mid-tower-case-mx330
MEtallic Gear Neo Silent has some similarities to the H510, for $50 (2x140mm + 3x 120mm, or 5x 120mm)...
https://pcpartpicker.com/product/3YgQzy/metallic-gear-neo-silent-atx-mid-tower-case-mg-ne520s_bk01
Phanteks P300A Mesh - $60, well reviewed case (3x 140mm or 120mm + 120mm only in rear)
https://pcpartpicker.com/product/cr...300a-mesh-atx-mid-tower-case-ph-ec300atg_bk01
I'll keep these in mind. I like how on these they have the cover for the power supply at the bottom. Unless I decide that RGB is where I would like to go, most likely I'll keep my eyes on one of these. Thanks!
If you are thinking about "upgrading" to NZXT H510 and believe tempered glass panel is a waste of money, what makes you want to upgrade? I have a machine running in Coolermaster HAF 912 case which I had bought about 5 years ago from Microcenter for $40 after rebate. It is a clean and simple case easily worth $70. Are there specific reasons which compel you to look for another case?
