Hi everyone,
I've had my eye on the Asrock Z77 WS motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813157336&Tpk=Asrock%20Z77%20WS&IsVirtualParent=1) , because it's a Z77 board that seems to have a PLX chip and is ATX instead of E-ATX. In the description, it says that the motherboard allows x8/x8/x8/x8. What confuses me about this is that the board should have 7 PCI/PCIe slots, in which case installing 4 double-wide graphics cards would bring the total of needed expansion slots on the case to 8. However, I've only found a few mid-tower cases with 8 slots, and all of them are out of my price range. My question is, will this motherboard be incompatible with cases that only have 7 slots, despite them both being the ATX form factor? And if it is incompatible, where would the conflict be?
As a secondary question, is there any Z77 CPU that won't be a bottleneck for 4 GTX 670s or GTX 680s? I'm planning to build gradually, adding better components every few months, and since I'm starting off with Z77, I don't really want to completely switch out the motherboard for an X79 board and CPU if I do get 3 or 4 cards. If you have a better solution for someone who can only save up 500 dollars every 6 months, I would be happy to hear it
BTW, this is somewhat hypothetical, as most likely, I'll wait until Z87 and GTX 700. However, if this problem arises again in an Z87 board, I want to know what to do.
