ATX motherboards dimensions/measurements
razerg
662
I need measurements for ATX motherboards. But not size i know it's 305x244mm. I need placement of IO Shield, expansion slots and 24pin connector. Now i know not all motherboards have the same placement of 24pin cable but i just need the closest possible numbers.
The ATX Form Factor is an industry standard. The location and size of the expansion slots and the rear I/O panel are the same for all ATX motherboards. It would be an extremely rare case where the 24pin cable of the power supply is not long enough to reach the 24pin power connector on the motherboard.
-Wolf sends
I'm not talking about the power cable. I'm talking about 24pin plug on the motherboard not being on the same spot on every ATX motherboard. I know location and size of IO shield and expansion slots are standardized, but i need those measurements.
I found it here http://www.tomshardware.co.uk/forum/307917-30-case-shield-dimensions
Thanks anyways.
