ATX Power Supply with MicroATX Mobo
jacobc22345
This may seem like a dumb question, but can I use a standard ATX power supply with a MicroATX motherboard? Any responses greatly Appreciated.
the limitation doesn't come from the mainboard, it mostly comes from the case and if it has space limitations or size requirements
if it is a standard microatx case or bigger, most psus will work, if not almost all, including the very long ones
only the sff/sfx psus will not work, but because the form of the case doesn't match the form of the psu
