Ok so my cat got up onto my tower and pulled my VGA cord really hard and immediately after I stopped having display or usb power.i know it isn’t the cord or the tv because they work with my laptop just fine. I tried resetting cmos jumper and bios battery (properly grounded + wrist strap for everything), I’ve replaced my motherboard with a new one (same model), made sure my CPU is seated properly, checked and rechecked my mobo wires, and all I’m getting is a “no input” from my tv , the fans, the lights to my fans, and CDROM all show power. USB also still don’t work, no connection noise, no noise at all. I was hoping replacing my motherboard would fix it. I’m also not getting any beeps or boops when I start it up.
Do you suppose it’s the power supply or BIOS? I have an integrated GPU. Everything I’m working with is ATX. I thought maybe my bios setting automatically switched to DVI-D when my VGA got damaged but the problem with the USBs is a real issue that would prevent me from doing anything with BIOS if I manage to get into that menu. If I can’t narrow down the problem in the next few weeks I’m just going to ultimately take it into a shop.
Lenovo IMH6 Motherboard
Intel core i5 3650 (I think that’s the chip number)
12Gb RAM (8+4)
Seagate 2TB SATA (not sure what brand unless stated but I can check)
PCIE1 Wireless Card
500w Power Supply
SATA CD- ROM Drive (motor busted)
12Gb RAM (8+4)
PCIE1 Wireless Card
500w Power Supply
