B blackmarket Reputable Jun 22, 2015 3 0 4,510 Jun 4, 2016 #1 Rebuilding my PC and I don't remember if I used all 8 pins for the CPU header on my motherboard. When I try to fit them, they won't go in because they're not the right shape. I need these pins because I will OC my 4690k
Solution C C Calvin7 Jun 4, 2016 Difference between EPS12V and ATX12V 8 pin connectors http://www.jonnyguru.com/forums/showthread.php?t=2505
turkey3_scratch Expert Ambassador Jul 15, 2014 22,627 9 60,960 Jun 4, 2016 #2 Are you by accident trying to plug in PCIe cables? It should be split 4+4, if it is 6+2 or just 8 it's probably a PCIe cable. Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Jun 4, 2016 Solution #3 Difference between EPS12V and ATX12V 8 pin connectors http://www.jonnyguru.com/forums/showthread.php?t=2505 Upvote 0 Downvote Solution
