Audio and movie question
Jdperry
We do outdoor movies in the summer. I have outdoor speakers set up through my Harmon Kardon receiver. In the past I have always played the movie through a dvd player and run an s video out to my projector and the audio to my receiver. I now want to play a movie from my computer. I have the HDMI connection from computer to projector but can't seem to figure out how to get the audio through my receiver so I can use the outdoor speakers. Any ideas/suggestions? Thanks!
You should be able to connect the PC analog audio output (set to 2.0 for the outdoor speakers) to the receiver. You will probably have to set the PC to not output audio via HDMI in the video or audio controls. No advantage using digital outs if you have them since you don't have center, sub or rears outside.
HDMI/S/PDIF/Optical and etc because of copy protection you will need a device to extract the audio portion out. Only one digital signal is allowed. Without knowing the models of your setup, it's hard to give you more information. Analog doesn't have those hassles of copy protection.
A device like this will extract the digital audio. http://www.monoprice.com/Product?c_id=101&cp_id=10114&cs_id=1011412&p_id=10251&seq=1&format=2
Info on your setup?
Be seeing you, the Prisoner...
If your receiver can take HDMI in and HDMI out, you could connect the computer to the receiver and then to the projector.
