Audio Compression Problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I'm having audio problems on my XP Home
To troubleshoot, I went into Control Panel | Sounds and Audio Devices |
Sounds Tab
When I try to play any of the Sounds, I get the following message:
"Error: Windows cannot play the <path and file> file. The file may be
damaged or may use an unrecognized compression format. To resolve this
problem, replace the file or use Add/Remove Programs in Control panel to
install Audio Compression."
In the Hardware tab, it lists Microsoft Audio Compression Manager.
Under Codecs, I have:
IMA ADPCM Audio CODEC
Microsoft ADPM Audio CODEC
Microsoft CCITT G.711 Audio CODEC
Microsoft GSM 6.10 Audio CODEC
msg723.acm
Windows Media Audio
Indeo audio software
Fraunhofer IIS MPEG Layer-3 Codec
Sipro Lab Telecom Audio Codec
Microsoft PCM Converter
Any ideas of what is missing?
Thanks,
Martin Schmid, EIT, CCSA, MCDBA, MCSE
G
Guest
Guest
Try reinstalling the sound chip or card drivers
> Sounds Tab
> msg723.acm
> Windows Media Audio
> Thanks,
G
Guest
Guest
Tried that to no avail.
Thanks,
"Rho_1r" <Rho_1r@hotmail.com> wrote in message
news:5AA353D2-63C7-4484-BC40-A6AAAFB42BE6@microsoft.com...
>> Sounds Tab
>> msg723.acm
>> Windows Media Audio
>> Thanks,
Thread starter Similar threads Forum Replies Date
U Windows Legacy 1
