Audio Crackling and FPS Drops.
A few days ago my headphones started crackling. I figured that they were just getting old. The issue continued to get worse, until it made gaming impossible due to performance issues. Here is my LatencyMon results.
Highest ISR routine execution time (µs): 120.760
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.002760
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.003772
ISR count (execution time <250 µs): 48484
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
_
REPORTED DPCs
_
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1668.880
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 527.56 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.063454
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 527.56 , NVIDIA Corporation
Total time spent in DPCs (%) 0.186277
DPC count (execution time <250 µs): 477176
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 459
DPC count (execution time 1000-2000 µs): 7
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
_
REPORTED HARD PAGEFAULTS
_
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: msedge.exe
Total number of hard pagefaults 23260
Hard pagefault count of hardest hit process: 4428
Number of processes hit: 60
_
PER CPU DATA
_
CPU 0 Interrupt cycle time (s): 10.970469
CPU 0 ISR highest execution time (µs): 63.960
CPU 0 ISR total execution time (s): 0.044149
CPU 0 ISR count: 17620
CPU 0 DPC highest execution time (µs): 1668.880
CPU 0 DPC total execution time (s): 3.593553
CPU 0 DPC count: 336825
_
CPU 1 Interrupt cycle time (s): 0.881128
CPU 1 ISR highest execution time (µs): 80.280
CPU 1 ISR total execution time (s): 0.028379
CPU 1 ISR count: 13500
CPU 1 DPC highest execution time (µs): 103.860
CPU 1 DPC total execution time (s): 0.171656
CPU 1 DPC count: 17564
_
CPU 2 Interrupt cycle time (s): 0.573675
CPU 2 ISR highest execution time (µs): 20.120
CPU 2 ISR total execution time (s): 0.003073
CPU 2 ISR count: 520
CPU 2 DPC highest execution time (µs): 179.060
CPU 2 DPC total execution time (s): 0.087432
CPU 2 DPC count: 31949
_
CPU 3 Interrupt cycle time (s): 0.369328
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 68.140
CPU 3 DPC total execution time (s): 0.016425
CPU 3 DPC count: 4675
_
CPU 4 Interrupt cycle time (s): 0.455093
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 78.360
CPU 4 DPC total execution time (s): 0.021056
CPU 4 DPC count: 7208
_
CPU 5 Interrupt cycle time (s): 0.405944
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 43.890
CPU 5 DPC total execution time (s): 0.012543
CPU 5 DPC count: 4334
_
CPU 6 Interrupt cycle time (s): 0.570173
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 1430.550
CPU 6 DPC total execution time (s): 0.039873
CPU 6 DPC count: 11134
_
CPU 7 Interrupt cycle time (s): 0.421954
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 36.550
CPU 7 DPC total execution time (s): 0.012421
CPU 7 DPC count: 3711
_
CPU 8 Interrupt cycle time (s): 0.627496
CPU 8 ISR highest execution time (µs): 53.30
CPU 8 ISR total execution time (s): 0.005188
CPU 8 ISR count: 10161
CPU 8 DPC highest execution time (µs): 132.850
CPU 8 DPC total execution time (s): 0.054336
CPU 8 DPC count: 17060
_
CPU 9 Interrupt cycle time (s): 0.440543
CPU 9 ISR highest execution time (µs): 49.870
CPU 9 ISR total execution time (s): 0.000404
CPU 9 ISR count: 579
CPU 9 DPC highest execution time (µs): 45.340
CPU 9 DPC total execution time (s): 0.015554
CPU 9 DPC count: 4338
_
CPU 10 Interrupt cycle time (s): 0.693872
CPU 10 ISR highest execution time (µs): 120.760
CPU 10 ISR total execution time (s): 0.001829
CPU 10 ISR count: 2644
CPU 10 DPC highest execution time (µs): 212.320
CPU 10 DPC total execution time (s): 0.103661
CPU 10 DPC count: 23641
_
CPU 11 Interrupt cycle time (s): 0.660107
CPU 11 ISR highest execution time (µs): 49.890
CPU 11 ISR total execution time (s): 0.002177
CPU 11 ISR count: 3460
CPU 11 DPC highest execution time (µs): 75.920
CPU 11 DPC total execution time (s): 0.078428
CPU 11 DPC count: 15203
_
_
REPORTED DPCs
_
_
_
_
PER CPU DATA
_
_
_
_
CPU 3 ISR count: 0
_
CPU 4 ISR count: 0
_
CPU 5 ISR count: 0
_
CPU 6 ISR count: 0
_
CPU 7 ISR count: 0
_
_
_
_
_
