Question audio does not work, exclamation point on PCI port in device manager (even though my computer is able to beep when it starts)
abdullah_27
Commendable
Jan 16, 2017
5
ok , so these are my computer specs :
System Information
Time of this report: 1/16/2017, 20:38:57
Machine name: ABDULLAH
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.161011-0600)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 7483R76
BIOS: Lenovo ThinkCentre BIOS Ver 5CKT50.0
Processor: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2 CPUs), ~3.0GHz
Memory: 4096MB RAM
Available OS Memory: 3328MB RAM
Page File: 1785MB used, 4867MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Input Tab: No problems found.
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
ok, so i am guessing that most of your answers would be that i do not have a sound card installed in my pc , i have not physically opened my computers case to check , but i am sure that its there , reason being is that a few months ago , before my windows got corrupt and i had to install new windows , i was able to hear audio directly from my pc without the use of headphones or an ear piece , now , i am not able to do that , i constantly need to have an ear piece insterted into my pc to be able to hear audio or to play games , otherwise the games do not run at all. i am not really into computer troubleshooting and i do not know much about it as i am really just a 13 year old . i can tell tell you this information if it helps you out : when i go to device manager , in the section 'other devices' , there are exclamation marks in the ' PCI serial port ' and the 'PCI simple communications controller ' . now, i have tried to install the driver updates for these these two , thinking that that might be the cause of the problem , but when i right click on it and i select ' update driver software ' , the computer cannot find the update for these drivers. i have also checked under the sound , video and game controlllers section in the device manager to see if something was wrong with it , but everything was correct , i had high definition audio device and nvidia virtual audio device (wave extendable ) (wdm) installed , sio i dont see why there shoulb be a problem with my audio , any solutions? id really be grateful for an answer . Thanks in advance
