M migoholst Nov 3, 2021 2 0 10 Nov 3, 2021 #1 Hey, I have an audio driver that won't let my computer go to sleep or hibernate. It's the only thing that shows up with "powercfg /requests". And i can't find a way to stop it without closing it. Do you guy's have any ideas what to do? Audio driver (voicemeeter)
Solution Ralston18 Nov 4, 2021 Dig in a bit deeper: https://docs.microsoft.com/en-us/wi...ice-experiences/powercfg-command-line-options https://www.thewindowsclub.com/change-sleep-timeout-using-powercfg Key is to first identify what is actually preventing "sleep" and then, secondly, determine if that can be disabled or removed.
Ralston18 Titan Moderator Oct 11, 2014 39,397 4,371 146,290 Nov 3, 2021 #2 Is it being started at boot up? Look in Task Manager > Startup. If enabled , disable it there. Right click to to make the change. Reactions: migoholst Upvote 0 Downvote
M migoholst Nov 3, 2021 2 0 10 Nov 3, 2021 #3 Ralston18 said: Is it being started at boot up? Look in Task Manager > Startup. If enabled , disable it there. Right click to to make the change. Click to expand... It was. I tried turning it off and rebooting the PC. but it did not help, the PC still won't go to sleep🙁 Upvote 0 Downvote
Ralston18 Titan Moderator Oct 11, 2014 39,397 4,371 146,290 Nov 4, 2021 Solution #4 Dig in a bit deeper: https://docs.microsoft.com/en-us/wi...ice-experiences/powercfg-command-line-options https://www.thewindowsclub.com/change-sleep-timeout-using-powercfg Key is to first identify what is actually preventing "sleep" and then, secondly, determine if that can be disabled or removed. Upvote 0 Downvote Solution
