Question Audio enhancements causing problem error ?
jai360
67
so guys
i being using condenser mic WR 800 with usb adapter sound card it was working fine and all of a sudden im getting weired noise when i clicked
control panel - >sound i gave me this error message
// " Windows has detected that audio enhancements for the following device are causing problems
Microphone ( Realtek High Definition Audio )
would you like to disable the driver enhancements for this device ? " //
i tried uninstall microphone driver reinstalling it
then uninstalling PC audio driver Realtek and reinstalling it
but no use it getting same wired loud noise and low voice problem.
previously it was working fine ?
so whats the problem ?
does the C-usb adapter sound card failed and causing the problem ?
i have included the screenshot of the error message and normal waveform i used it get and noisy waveform im getting now in audacity.
please check screenshot
View: https://imgur.com/94XquoL
View: https://imgur.com/Z8IZfae
View: https://imgur.com/j4Ld7v4
Thread starter Similar threads Forum Replies Date
T Windows 7 0
Similar threads
Question audio issues
