Question Audio equalizer in game not working
May 1, 2023
Just got dead island 2 problem is the sound is bad like flat. I found out that the game doesn't use my equalizer at all Headphone speaker etc ( z170pro gaming realtek )
Its the first time i have this problem with a game. Other games are working just fine. Win 10
If the audio equalizer in your game is not working, there are a few things you can try to troubleshoot the issue:
  1. Check if the game settings are configured correctly: Ensure that the audio settings in the game are set up properly. Check if the audio equalizer is enabled in the game settings.
  2. Check the audio drivers: Make sure that your audio drivers are up-to-date. You can go to the manufacturer's website to download the latest drivers for your sound card or audio device.
  3. Restart the game: Sometimes, restarting the game can help resolve the audio equalizer issue.
  4. Check your sound settings: Verify that your sound settings are properly configured. Check if your speakers or headphones unmatched air traffic control mod apk are connected and working correctly. Also, ensure that the audio is not muted or turned down.
  5. Try using a third-party audio equalizer: If the above steps do not work, you can try using a third-party audio equalizer software. There are several free and paid options available that you can download and install on your computer.
If none of the above steps work, you may want to reach out to the game developer's support team or check their community forums for additional help and support.
  4. Check your sound settings: Verify that your sound settings are properly configured. Check if your speakers or headphones are connected and working correctly. Also, ensure that the audio is not muted or turned down.
Yep I had to do number 5 using a third-party audio equalizer and its working right now. Thx
