Audio from front and rear jacks not functioning correctly,
Dec 17, 2018
4
Recently installed a USB hub with audio jacks into my 5.25 drive bay. I installed it once to check it was all working and it all seemed ok, I then moved things about a bit and tidied up the wires and reinstalled this hub. On doing so this time the audio from both front and rear audio jacks no longer worked. It plays volume very quietly through one of the headphones but that is at maximum volume. I would understand if it was just the front audio jack messing up as i could have put the cable in wrong as i often do, however for both to be messing up like this indicates i have done something that is probably not very good, audio plays fine out of all other outputs its just the jacks.
Any ideas what i have done?
Similar threads
