audio help
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
i have xp pro i cant access the advanced volume control in the volume
control menu, i am trying to change from digital to analog can anyone help
when i drop the options menu i can see it but i cant access it, it wont
highlight
David, when you rt click on the Volume Control in the rt corner of the
Taskbar do you get a menu with two items?
Adjust Audio Properties & Open Volume Control? When you select Open
Vol Control>Advanced>do you get a
box you can check for S /PDIF enable?
"david damelio" <ddamelio@tampabay.rr.com> wrote in message
news:uxN4WsPoEHA.3424@TK2MSFTNGP12.phx.gbl...
> highlight
Did you install the audio drivers for the sound card or for 'on board
sound?'
Make sure you have the correct version of the drivers.
Michael
>highlight
that is the problem when i open the option box on the volume control i can
see the advanced control selection but i cant highlight it to get to the
options
"Rich Barry" <rbarry@NOTsocal.rr.com> wrote in message
news:OLs745PoEHA.644@tk2msftngp13.phx.gbl...
>> help
>> highlight
