Audio help
What model is it? There were 4 different versions of the f700, the CTO, EF, EM and XX.
And is it a 32 or 64 bit version of windows? (press start > right click computer > select properties > look beside "system type")
Make sure it not on muted
Make sure it playing out of the specker you want it
Control Panel\Hardware and Sound\sound
Check the usb power cable
Check the Audio Cable
None of this work
Command prompt
Msconfig > Services > Windows audio
Make sure it running
