[SOLVED] Audio interacting negatively with 3060 Ti ?
I just purchased and installed a 3060ti and it isn't allowing my Sound Blasterx G6 to work correctly. Everytime I try playing a game, after a few seconds, it disconnects from my computer. I tried using my old graphics card, which is a 1050ti, and it worked perfectly fine. Is there any way I can fix this?
EDIT: Fixed it, I had to change my PCIe mode from Gen 4 to Gen 3 in the BIOS.
