audio interface vs. audio amplifier?
taynethemayne
18
Hey y'all, I'm a big noob when it comes to audio so bare with me here. I'm looking to get into Livestreaming some games that I play and I recently purchased a new pair of headphones that were on sale, the "Beyerdynamic DT 770 PRO Headphone, (250 ohms edition)". From my basic knowledge, I know my sound card on my computer is not enough to get the full power out of these headphones, so the few questions I have are:
-should I just get an amplifier for the headphones, or would getting an audio interface would be a better option?
-Is the PreSonus AudioBox USB 2x2 a good enough audio interface for my needs?
I am on a budget so I cannot afford anything more than $150, any recommendations can go a long way for me.
Cheers!
Most streaming software will not care about your sound card. You can use a mic to talk while streaming and even use a webcam for users to see you as well.
As for the headphones, You can try them to see if they work. With a 250ohm set, your sound may be more quiet than you would like(A high ohm number uses less power at the same voltage. So 0.5 volts into 250ohms is 0.001watt vs 0.01563 watt for 32 ohm headphones). In those cases, any decent sound card with an amplifier for headphones should work(I am sure others have recommendations for that).
We are for the most part past the point of needing dedicated hardware for streamers since most video cards can capture/compress video in real time.
Perfect! I will look into just getting an amplifier to meet the needs of the headphones. Are there any amps for the headphones i have that you can suggest that are on the cheaper side? I have found these over amazon that is recommended
https://www.amazon.ca/Version-Upgraded-Lepy-LP-2020A-Amplifier/dp/B00V9AYMZ4/ref=sr_1_1?ie=UTF8&qid=1479696312&sr=8-1&keywords=audio+amplifier#Ask
Sorry once again, but I'm new to this audio stuff.
Cheers!
actually.. not quite
the reason for using an interface is not so much the software they can come with (which can be nice in some cases) but for using XLR style microphones, listening to your voice while you record live and being able to mix in multiple sources at once. many professional streamers are using such devices as most use xlr style microphones, listen to their voice live and may need to mix in or output to different devices.
many have a weak amplifier built in which normal headphones will work with but for higher power headphones you would want an amplifier connected on the output. similar to a pc, while your dt770 may work with it minus an amp it wouldnt be stellar without using an amplifier.
there are many cheap audio interfaces out there although i tend to recommend things like the scarlett solo which i know are quality products. good amplifiers to pair with it would be the schiit magni, o2, fiio a3 in that order. i've heard of some quality issues on the cheaper ones which is why i dont generally list them but for on the cheap they are fine if you are okay with some quality issues.
if you do not care about listening to your voice while you record (you can do this without an interface but may have a micro lag delay through windows), do not care about mixing or native XLR input (you can use phantom power adapters and xlr-3.5mm adapters instead) or just plan to use a usb mic (interfaces do not work with usb) you really dont need an interface and a decent soundcard would do (or using onboard+amp, soundcard+amp, external dac+amp, etc).
as far as just amplifiers, the schiit magni will power just about anything on the market and could be used for a long time through any of your future upgrades. the o2 is not far off either and is a quality unit but more expensive. for on the cheap the fiio a3 is not bad but given its portable i've heard of noise while charging and its not going to handle every headphone on the market well.
explanation of some of the options you are left with:
onboard audio + external amp
cheap option, powerfull enough to drive your headphones, quality of the sound still relies on your onboard dac so may not be quite up to snuff or may have issues depending on how good your onboard audio is.
internal soundcard
cheap option, strong cards like the z may work although will still lack power to drive high power headphones effectively. you get virtual surround sound, software and some other options you may or may not need.
internal soundcard + external amp
mid level option, amp is strong enough to drive headphones yet if you use a soundcard like the dx you can have a good quality dac unit as well as software for virtual surround and aux outputs and inputs for things like speakers, analog mics, etc. generally the go to choice for people who want both virtual surround as a must have and need to power headphones a soundcard alone can not handle well. why the dx? it has a fairly weak amplifier yet the same dac as the $200 stx. in comparision the z has a stronger amplifier but weak dac.
external dac + external amp
this route is limited to stereo only (except using razer virtual surround only) but is certainly high quality. products range in price from fairly cheap (e10k, audioengine d1) to reasonably expensive but still budget priced in terms of audio (schiit magni + modi stack). expect quality audio out of such setups but you are limited to just one thing: quality stereo audio output for headphones. some (modi uber edition for example) adds aux outputs or optical inputs. if you use a usb microphone there is no real need to worry about having a soundcard or interface.
so, what is best for you? that depends..
A) do you plan to use an xlr microphone?
B) do you need to live monitor your voice?
C) do you need virtual surround sound?
D) do you need aux input/outputs
for on the cheap, an e10k would likely work (ext dac+amp combo box). if you want virtual, the xonar dx + schiit magni (or a3).
the lepai 2020 amp is meant for speakers not headphones. plug headphones into a speaker amp and you will likely fry them if you turned the volume up. headphone amplifiers are marketed as headphone amplifiers.
Thanks for the input! The microphone I am planning on using is Samson Meteor Mic USB Studio Microphone (https://www.amazon.ca/dp/B004MF39YS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2PHFNYAMAAFFS&coliid=I1RC1FTRBOQ0PZ&psc=1)
Would this amplifier be sufficient enough to get the best results for the dt770 pros? https://www.amazon.ca/dp/B01ANENCB6/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2PHFNYAMAAFFS&coliid=I2LZPTTK4R89VV&psc=1
Appreciate the long explanation, I will be looking into those products with black friday right around the corner
Cheers!
I'm going to best in detail help you understand how sound works on a computer first to better help you understand what or how you should go on looking for a device.
Computer CPUs do the workload unless there is a DSP chip on a audio interface, ( These are for direct monitoring and adding effects from the native interfaces software, like compression,Reverb,Gates etc ). But a Audio Interface without a DSP is only doing one major thing. It's reading a digital signal from ether a USB,Firewire,Thunderbolt, and or PCI /PCI-E. (There are laptop only internal add-onboards as well). Most cards are doing the same thing, Converting this digital signal to analog so you can hear it. Once's it's converted you can out put that to a number of ways.
With streaming you can go ina number of ways to get this done.
You would need to know
-How many In/Outs do you need
-Do you need direct monitoring,( Being that you're wanting to stream, I'm guessing you would want to add gates and or compression to the Mic so you don't seem to loud.
-What type of interface USB,PCI / PCI-E,Firewire,Thunderbolt?
There is a ton of converters on the market so knowing what you would need would be the place to start. I'll see what i can look up as well as i'm doing search's for DAC"s atm. I'll message what i find.
