• Now's your chance to speak with MSI directly! Join our AMA and get entered to win a RTX 2060 GPU, plus more! Ask your questions here.
    Catch the next Tom's Hardware livestream on May 28 at 2PM Eastern: Catch the show here!
    Need Hardware Help? Include the Info Requested Here.
  • Join our Best PC Builds competition and get on the Tom's Hardware home page. Check it out here.
Question Audio Jack Front and Back not working
TheeCatalyst21
40
I don't really know what could have cause it to fail, but I was playing Fallout 4 then the game crash as well as my PC.
I've already installed the latest Realtek Audio drivers and tried to do the Nvidia Audio as well. My monitor dosen't have any built-in speakers, but my PC does and it's working fine.
Uninstall & Reinstall didn't work for Realtek drivers, but my Headphones are working fine, also tested a Plantronics headphone with a usb dongle(note: it's using a RJ11)
I found a usb dongle for a 3.5 jack online and plan on using it once it's delivered.
PC Specs:
HP Compaq 6000 Pro SFF
Windows 7 Professional
Intel Core 2 Quad 9400
Hewlett-Packard 3048h motherboard
GT-1030
Sorry need to edit. The built-in speaker in the PC is working, my headphone is the one not being detected.
Selynelar
51
I had similar problem like yours. My problem has been figured out. The Motherboard Audio chip has been died. So I changed it(The motherboard). Since it is working flawlessly. I hope I could help.
Selynelar
51
Try to go into your bios and check if your on board audio is enabled. When you connect any jack in the rear try to set your output for speaker or something like that. Check on the tray that the sound output is set to your speakers output if you connect with jack it shouldn't be digital output or the monitor/vga.
For now these are my advices. These steps i did when finally I decide to take my computer into a computer store to repair it :(
Oussebon
Upstanding
Feb 17, 2020
269
50
290
6
The monitor doesn't have speakers you say, but does it have a headphones socket?
In which case you could have the Nvidia GPU provide audio to the monitor via HDMI or DP, and then connect the headphones to the monitor.
Which would be cheaper than buying a sound card - as long as the monitor has a headphones port, and an HDMi/DP input, anyway :)
TheeCatalyst21
40
Thank you for your time for trying to help me. I'll be going thru the usb or the pci expansion.
It does have 1 pci-e x16 I have the GT-1030 there and currently not using the pci slot.
TheeCatalyst21
40
Sorry for the confusion, the monitor does not have a audio jack. The monitor is a hp compaq la2205wg.
