Question Audio jack looks normal but dosent work properly
sisedofficial
6
so i bought a cheap headset ( NOD G-HDS-003 ) and it came with 3.5mm audio jacks. I put the audio jacks on and it worked perfectly ( after realtek was installed ). now it just does not seem to work. i've got only one working audio jack port and that is my motherboards the case's jack has a jack stuck in there, it also has some superglue to my failed attempts to remove it. anyway the headset can only produce several types of sound ( when full in ) guitar and other types of sound just dont work. if i twist it it seems to work normally for a few seconds. when its halfway in it works normally but with a good loss of sound quality. i plugged in some earphones to check if the issue was the port or the jack itself, turns out its the jack so my headphones are not working. I have no idea how to soldier is there any way i can fix my headphones? i got a very close look at the jack but it seems perfectly normal.
