Question Audio not coming out of the monitor
Mar 31, 2024
4
Please keep it to 1 thread.
I need help with my audio not coming out of my speakers. I tried checking the sounds and troubleshooting. Nothing worked. Everything is updated. My volume is at 100% on my monitor so I know something's wrong. I just built this PC so idk how to fix it. Can someone please help?
Update: I only get audio from headphones. I installed, Realtek and AMD. Updated my PC. And still nothing This is a new build. I have an HDMI cable connected to my Video card to my Monitor since that is the only way it displays anything on the screen.
what connector and/or adapter are you using to connect the monitor to the pc?
system spec? monitor model?
HDMI, Monitor Model: Philips V Line 24 LCD. System Specs: CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor, Motherboard: Asus ROG STRIX B550-F GAMING WIFI II ATX AM4 Motherboard, Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory, Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive, CASE: NZXT H5 Flow, GPU: MSI RTX 3060 Ventus 3X 12G OC GeForce RTX 3060 12GB 12 GB Video Card, and PSU: Corsair CX550M 550 W 80+ Bronze Certified Semi-modular ATX Power Supply.
Need the exact model, V line is the series.
If you open up the Control Sound app, what devices does it show; does it show anything like Speakers Connected or does it show anything like Speakers Unplugged? If you open up the Control Panel Device Manager and check all of the Sound related devices, does it indicate that they are all running properly? Usually with HDMI output the Intel HD Audio Driver for Display Audio is used; perhaps you need to install that. You could use the Intel Driver and Support Assistant app to check that.
