Audio not working after case upgrade please help with driver upgrade
newbuilder0123
17
So in another thread I was told that I must make driver adjustments because with my old case I used AC'97 audio and this new case only uses HD audio.. How do I go about this change? Please help??
Intel® Desktop Board DH61WW Classic Series is the mobo name
Corsair carbine series spec-01 is the case
Please help me, thanks for reading
In the main page for your audio driver (it probably has a small icon in the System Tray you can double-click to open it) there should be some kind of selection for the front panel. Some applications use a tiny wrench to indicate where settings are made.
