Audio not working (aux)
texintaco
221
Hi,
Ok so my USB headset is working fine, however, my Realtek audio is not.
When go to system Info, there are 2 high def audio devices that are disabled
High Definition Audio Controller PCI\VEN_10DE&DEV_0BEE&SUBSYS_15573842&REV_A1\4&2DB3ECDA&0&0108 This device is disabled.
High Definition Audio Controller PCI\VEN_8086&DEV_A170&SUBSYS_A1821458&REV_31\3&11583659&0&FB This device is disabled.
how do i fix this so i can plug in a speaker?
I'm using a gigibyte h110m-s2h
Hmm, sometimes a driver update or failure can disable it for some reason. It may be because of your USB headset install.
Unless it occasionally disables it by itself in the future, I don't think there's any problem with your computer.
