Audio not working in GIGABYTE B85M-D3H Motherboard
ZaHiD298
17
Just installed windows 10. Everything is working good but there's problem with the sound. Sound driver is installed too but there's no sound output. I have installed the audio driver like 10 times and tried different versions as well but no result
Any kind of help would be highly appreciated
Are you trying to plug your speakers/headset into the front audio ports or the rear motherboard audio ports? If the front, you have to make sure the audio cable is plugged into the motherboard.
Problem solved. Actually I haven't tried the driver given with the motherboard CD rather I download it from the GIGABYTE website and installed it. I think that's the reason mainly. And avenseth12, thanks for your reply :)
