[SOLVED] Audio not working on MSI B450M-A PRO MAX 2 motherboard ?
11
I recently built my first gaming pc, and the audio is not working from any of the ports. I double checked and made sure everything was plugged in properly. I also made sure I have all the drivers, but wired audio still has not worked in any scenario on this computer. I connected my Bluetooth headphones to computer, and everything worked fine, it's just that when I try connecting any wired audio devices such as earbuds or speakers to the computer, that it does not work. Do you guys have a solution?
What BIOS version are you on for your motherboard? What OS are you working with? Please mention your audio gear that you're pairing with your platform.
I am pretty sure the bios version is A.00 on Windows 11. I tried using Logitech Z130 speakers and some knockoff Apple earbuds. I tested the speakers and earbuds on different devices and they worked fine.
I recently built my first gaming pc, and the audio is not working from any of the ports. I double checked and made sure everything was plugged in properly. I also made sure I have all then drivers, but wired audio still has not worked in any scenario on this computer. I connected my Bluetooth headphones to computer, and everything worked fine, it's just that when I try connecting any wired audio devices such as earbuds or speakers to the computer, that it does not work. Do you guys have a solution?
Did you set them as default devices ?
Reactions: drea.drechsler
Update: Since it seems like nobody can find the solution with, I am strongly considering returning and replacing the motherboard. Since nothing else has worked, I am thinking that there is a problem with the motherboard. In case you guys had any thoughts on this choice, please leave your thoughts in case I have not returned the mobo yet.
Also I forgot to mention, I bought the motherboard used on Amazon.
