L Lbercume Reputable Jan 18, 2016 1 0 4,510 Jan 18, 2016 #1 Trying to connect an old Phillips DVD/ home theater unit to a new LG - 49" Class (48.5" Diag.) - LED - 1080p - HDTV Tried HDMI cable and red/white audio in/out cables but no sound
Solution A A americanaudiophile Jan 19, 2016 Without model numbers can't be exact. Likely your TV has optical audio output. If the HTS doesn't have optical in then you can use a DAC like this one http://www.parts-express.com/parts-express-dac-digital-to-analog-converter-%2851-compatible%29--180-999 to convert to an analog output that can be used with the HTS.
A americanaudiophile Titan Aug 27, 2008 13,663 0 101,360 Jan 19, 2016 Solution #2 Without model numbers can't be exact. Likely your TV has optical audio output. If the HTS doesn't have optical in then you can use a DAC like this one http://www.parts-express.com/parts-express-dac-digital-to-analog-converter-%2851-compatible%29--180-999 to convert to an analog output that can be used with the HTS. Upvote 0 Downvote Solution
