Question Audio not working
Jun 28, 2022
8
After i did something my front and back audio panel dont detect anything connected to it anymore, i got a dell Optiplex 990MT
What might that something be?
Have you tried uninstalling and reinstalling your audio drivers for your prebuilt? Check and see if you've got any BIOS updates pending for your prebuilt. What OS are you working with?
"something" is trying to move the motherboard from a new case but didn't worked as expected so i moved it back to the old case
i tried with many versions of the audio drivers, i got the latest video update, im running Win 10
(Audio works from devices that aren't connected via jack such as my monitors(connected via hdmi,dvi-d), camera and desktop mic)
Edit: the audio still doesn't work on a different OS, i also tried disabling and enabling the audio option from the bios and still
Ok after checking the pc, two pins are bented from the front panel's motherboard connection, that might be the cause im not getting audio from the front
edit: neither that is the issue 🙁
