Audio output doesn't work. Please help !
MaheR26
17
I have a motherboard BIOSTAR NF560-A2G and the speakers output (green) doesn't work. Other two work fine (blue - line in, and red - mic). Is there any way that I can connect my speakers without spending money on soundcards?
Thank you.
Will the sound quality be the same if I connect a front panel to the motherboard? - because the audio chip works just fine. Only the output on the motherboard doesn't work fine because the small metals are probably displaced inside the output. I can not make an acces to them, they are too small. So I'm trying to connect the speakers other way.
