Audio Output Switcher Ideas
redfinger
43
Hey
I have speakers and headphones I use in my PC and am looking for a solution to have a switch I can use to switch between these, I want them both to be connected with a switch.
A cheap double pole double throw(SPDT) switch can be used to make a diy solution to this problem.
Seeing as you can buy them premade, that may be your best option if you are not the DIY type.
I think software would be my first option too however(and I have the switches are plugs needed to build one, just not something I need).
