Recently reformatted my computer to give it a bit of a cleaning up. It had Windows 7 Home Premium (x86) before the reformat, as well as after. No hardware has changed.
This is on a Dell Optiplex GX620
After the reformat, I'm getting audio popping and crackling. I've tried both my onboard Realtek AC97, and my PCI Soundblaster Audigy 2. Both give the same audio troubles. Note that both soundcards are not active at the same time.
A latency tracking software shows high red latency (3000+) when the popping and cracking occurs. (I forget the name of the software...I'm at work at the moment.) and down in the green when the system was idle at desktop.
Also, When I tried Windows XP (x64) SP2, the same audio trouble occured. However when I tried Linux Mint 13 (both a LiveUSB and a full install) there were no audio cracks and pops.
All drivers are up to date, including chipset drivers.
I've made sure the active soundcard was on it's own IRQ channel, and this did not help any.
Also I've tried a reformat, and letting Windows Update handle all the drivers for everything, this did not help.
I've also installed AISO4ALL, and this seemed to do no action whatsoever, nor changed the audio issue.
I'm sure you need more information, but I'm not sure what, and I'm at work at the moment. Please respond with whatever info you need, and I'll gladly post!
Thanks in advance.
Thanks in advance.
