Audio problem(Asus x555lab)
Nefalemm
Commendable
Oct 8, 2016
Hi I am using Asus X555Lab, when I am playing the nusic if i lift up my laptop the audio stop coming to the speakers/earphones,in order for it to come to the speakers i sleep it for about 5 sec......So i would like to know what might be the problem or what should i do?
It if stops working when you move it I would assume a loose connection.
If the laptop is under warranty, I would contact the manufacturer. If it isn't, well then it is up to you if you feel comfortable opening it up and looking yourself, or taking it to someone to do the work for you.
