Audio Problem on new build
Huike
21
With my new M5A88-VEVO board build I have gotten everything working great except for sound. I've troubleshot till my hands bled and to no avail. The on board card is a ALC892 realtek card. I've installed the drivers for it that came with the board, nothing. I uninstalled that and installed the drivers from the site, nothing. Here's the weird part, I even put in a soundcard that I KNOW is good and downloaded the drivers for that, no sound.
OS Name Microsoft Windows 7 Home Premium
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer System manufacturer
System Model System Product Name
System Type x64-based PC
Processor AMD Phenom(tm) II X6 1100T Processor, 3300 Mhz, 6 Core(s), 6 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 0504, 6/14/2011
SMBIOS Version 2.5
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 16.0 GB
Available Physical Memory 14.1 GB
Total Virtual Memory 32.0 GB
Available Virtual Memory 29.8 GB
Page File Space 16.0 GB
Page File C:\pagefile.sys
Please help, I've literally tried everything before coming here.
Edit: It also recognizes when I plug in the speakers (as an audio device) and it looks like sound is playing in the volume mixer, except there is no sound... the speakers in question worked great on my other computer.
If your GPU card has HDMI capability then it is likely that Win 7 has put your GPU sound chip as the default sound device. Go to Control Panel / Sound. Check to see what the default device is. Make sure it is your onboard Realtek.
I'm plugging it into the back jack, the green one yeah. Default under playback is "Speakers - Realtek High Definition Audio" and "Realtek Digital Output - Realtek High Definition Audio"
Double click the speakers from the Sound control panel, and verify this:
On Levels Tab, make sure there are no red circles with lines (turned off symbol) next to any of the items in the list. Make all volumes 100%
On the Ehancements tab, click the box that says Disable all Sound effects, an click the box that says Immediate mode.
On the Advanced tab, make sure both Exlusive boxes are checked. Also, try setting the quality to 16 bit 48 khz.
Also if you have headphones, try them in the same jack just for verification.
well, I originally responded to this thread because my mobo did the exact same thing. Every single thing I could think of short of reinstalling windows was done. I just bought a new soundcard to solve my problem, but you tried that and it didn't work. I am not sure else what to suggest, I'm stumped.
