[SOLVED] Audio Stuttering
Feb 13, 2020
every time i get into a firefight where there is tons of noise, in splitgate for example, my audio lags and stutters. any fix to this and is it something to do with my audio settings?
Anything helps
Update your post to include full hardware specs and OS.
Audio: Headset, earbuds, speakers.....?
Use Resource Monitor and Task Manager to observe system performance. Just one tool or the other at a time.
You may be able to spot some bottleneck or other system parameter that corresponds with the lags and stutters.
It's also an online multiplayer game so maybe sound has a secondary importance when the bandwidth of the server gets exceeded.
Running dpc latency will give your system a test and will tell you if there is some driver issue that might be causing sound to ill behave.
