Audio sync issue
Hot__Snowman
I'm on an HP Notebook and lately some videos I play off of firefox or Chrome are not syncing correctly. It's very noticable, by 2 or 3 seconds, and I'm using an ethernet cable and my audio drives are up to date I checked. This is driving me mad and I don't know what to do, any suggestions?
From your PM:
"Hey, sorry honestly..I cant find the reply option..I'm on mobile if that's relevant but the options not there. Anyways the issue happens when the video player is streamed on alternative sites I guess. The video I'm trying to play is off a site called thevideo.me from primewire.ag if you know those, I'm just trying to figure out is the point useless and should I just reset the system or is there amother fix.. "
If the problem is specific to certain websites then the problem is not likely to be with your system.
.me is Montenegro, .ag is Germany.
Could well be communications problems due to traffic, poor site design, etc..
Found this link:
http://currentlydown.com/primewire.ag
They may have a problem and are trying...
Just "some videos"?
Anything common or unique with respect to those video's: e.g, source, player, directory, etc..
Do the videos play without problem on other devices?
Try to narrow down the circumstances between playing with sync ok and playing with the sync problem.
From your PM:
Found this link:
They may have a problem and are trying to fix it. Wait a bit. Contact them if possible.
