audio track turned gray in Vegas, audio doesn't play.
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Help!
I did not, not lock the aucio track, but it tunred a gray color
as if I highlighted the whole track, and the audio won;t play.
If I click the cursor somewhere, it does not remove the gray.
how do I get it back the way it was? I don;t know what I did.
Thanks,
Tracy
Sounds like you hit the mute button on the audio track header. Look at the
track header on the left side of your audio track. Notice the yellow circle
with the slash thru it? Click on it and it will turn to a grey circle.
Craig H.
or perhaps you hit 'solo' on another track. Look also for the button that
looks like an exclamation mark.
"HighPeaksVideo" <highpeaksvideo@aol.com> wrote in message
news:20040508230502.21491.00001082@mb-m10.aol.com...
the
circle
> Craig H.
On Sun, 09 May 2004 04:24:29 GMT, "Terry" <replytothegroupzzz@zzz.com>
thanks guys, for your advice.
It wasn't any of those things, so I just re-installed the program,
since I don't have time to fiddle around right now. Viola!
Thanks,
Tracy
On Sun, 9 May 2004 14:56:20 -0400, tracym@askme.net wrote
(in message <ckvs90lhpl9ge0kag2qfd6f9c9f910k0tn@4ax.com>):
> Thanks,
> Tracy
In PTLE, I have had several situation in which the mix automation of a track
has been "lost". I can see the graphic rubber band line, but no moves happen.
I copied the track and pasted it into a new track and everything was fine.
Regards,
Ty Ford
