Hey guys how's it going? Seems I got a tricky one for you all.
I recently opted for the free Windows 10 upgrade (still debating if it was worth it) from a Windows 7. Long story short, there was a new problem every day so I just wiped everything and did a clean install hoping the old windows 7 files would stop clashing with the new windows 10 files. All went well and was working fine when boom my speakers start acting up. Don't know what I did to trigger it, it just started doing this.
Basically, when using my USB connected headset, everything runs fine, sounds nice, no problems. When I change over to my desktop speakers though, all audio and video goes into "slow motion" and makes obnoxious sounds. Computer doesn't lag, just audio and video for YouTube, games, etc.
I've tried reinstalling drivers via device manager and it says it's all up to date. I just tried installing Realtek audio driver manually and now it won't even play sound through the speakers. I know the speakers are fine because they sound beautiful when plugged into my ps4.
So, I'm not sure where to go from here. Ideas?
Update: After installing Realtek and doing a restart, the speakers are in fact making sound, but now it's also extremely quiet and scratchy. Had to crank it to max just to hear anything.
Update: May have fixed my problem, at least temporarily.
I went to device manager and deleted the speakers then restarted so that it would auto reinstall them. Seems to work fine again... Hopefully it will stay that way.
Update: As I had guessed, it was only temporary. Sound and video just started going all slow motion again. Back to square one and back to the drawing board...
Is anyone else having this problem/knows a fix for it?
