[SOLVED] AURA\RGB issue
n_smash
Motherboar: Asus Prime h670-plus d4
Case: Gamemax Revolt
CPU Cooler: Deepcool Gammaxx 400 XT
hi
i'm having a RGB problem with a new system. there are 5 RGB fans in total in my case. 4 of them came with the case and being control with case's RGB box and its switches. i'm planing to buy a cable (they didn't include it with the case!) to connect the box to motherboard for using RGB software.
now the problem is the cpu cooler. its just static in the rainbow state. i installed AURA and it won't do anything... there is no cpu cooler section in it, and when i change color or effect nothing happens...
HOW CAN I CONTROL CPU COOLER'S RGB ?
Should i plug the cpu fan to the RGB headers on the motherboard? Can i even do that? because it looks different . If so, WOULD ITS SPEED BE AUTOMATICALLY CONTROLLED?
Is there any other way?
hi
Should i plug the cpu fan to the RGB headers on the motherboard? Can i even do that? because it looks...
hi
I don't think you can change that fan RGB since it says a static RGB fan.
Edit you could replace the cooler fan to one you can control as long as it's still able to cool the processor.
Reactions: n_smash
