I have an HP Pavilion Desktop (still on hardware warranty for a few more months). I've always had great luck with HP products and with their support. But this time, I'm running into a wall with their support dept. I have had an issue w/the (wired) internet connection on this PC since I got it. When going to any web page, often I get an error that the Internet is not connected. In network properties, I can watch as the network actually connects and disconnects every few seconds. I can temporarily fix it by going to the NIC card's advanced properties and changing Speed & Duplex to 10 Mbps half or full (i.e., turn off Auto Negotiate). But it keeps getting reset back to auto negotiate by Windows or something (not sure what is doing it), which is frustrating.
I have found enough information on this forum and general searches of my internet engine to know that it is a problem with auto negotiate, and thus a hardware issue. But trying to convince HP support of this is another story. They insist that it is likely a software issue and that I pay for their "Smart Friend" service to go through all the troubleshooting steps ($14 per month fee + initial $35 startup fee). I don't believe this is a software problem, and refuse to pay this money. I am going to try a different ethernet cable "just in case" (addendum -- changing cable did not help).
Does anyone have any other suggestions as to how to definitively show that it's a problem (or not) with the NIC?
As a side note, I ran a network component diagnostic test (via pressing F2 while booting) and this is the message that came up (but no error code):
"UEFI Networking does not appear to be supported or enabled on this system. Please check the BIOS settings to make sure UEFI network option ROMs are enabled and that UEFI network boot is enabled."
PS - I did update the BIOS, just a few minutes ago, yet the network is still dropping after the BIOS update. The software driver on the Realtek PCIe Family NIC is also up to date.
Update - 9/24/16: Thank you for your suggestions. HP would not accept that booting from Linux USB results in same network dropping issue as proof that it is the NIC (although that was a great idea - thanks!). Their front end support simply won't talk to me about it being hardware-related (and thus, warranty-covered) until I pay $99 to go through their SmartFriend software support to diagnose the issue. I refuse to do that. I will live with the workaround of changing the NIC to 100 Mbps Half Duplex on the speed settings. I have also ordered a $11 USB Network adapter, which I am going to see if works better. If it does, I'll try and switch off the built-in NIC altogether and use the USB network connection instead.
Update - 9/26/16 Did what I stated above, and the $11 USB Ethernet adapter worked flawlessly with auto negotiate setting out of the box. Disabled the built-in HP NIC and everything is working great now.
