[SOLVED] Auto over clocking?
Jan 26, 2019
I just completed my 1st build.
Ryzen 5 2600x
GeForce RTX2060
Asrock b450 itx
Corsair vengeance 3000 16gb of ddr4 ram.
I was told to download a program call CAM and Ryzen master. Upon running cam I noticed my cpu is running at 4.1-4.2 idle speed.I don’t want to over clock anything just stock. I’m new to pc gaming so I don’t want to mess anything up. Is this safe?
What your seeing is more then likely AMD XFR2 which auto overclocks when needed, it won't hurt anything as it adjusts the overclock based on temp/voltage. Ryzen Master is fine but if your talking about NZXT CAM software then I'd dump it as HWmonitor is much better.
https://www.cpuid.com/softwares/hwmonitor.html
I'd only use NZXT software if your using a NZXT AIO for cooling.
