Automatic Fan Control Help
jonasbensimon
43
Hey,
So i used to use the Asus Z97-A motherboard, which to be hoenst was great, but now i was given the gift of the Asus Sabertooth X79 and am a little dissapointed. With Z97-A (cheaper) there was the great addition of AI Suit 3 with Fan expert.....its great. Now with the Sabertooth X79 (more expensive) there is only Ai Suit 2, and on top of that there isnt even the capability to use Fan Expert.....which in my opinion is much needed.
Anyways my question is without having to buy a Fan Control is there any way to get Fan Expert for this mobo to work or is there any software that would control my fan "Automatically" (as in when the temp raises the CPU fan and 1 Chasis Fan gets faster and as it loweres they go slower)?
At this point i havnt figured any solution and my two computer fans are extremely loud since theyre always at full speed.
Anybody have any suggestions?
thanks!
My fans set up: H80i connected to the CPU fan and i took one of the fans to put it at the bottom of the chassis.
Built: http://pcpartpicker.com/user/jonasbensimon/saved/9zY2FT
No it actually doesnt even have Fan Expert, its quite annoying and questioning, i dont understand why they didnt include it with this particular mobo.
check it out: http://www.asus.com/us/Motherboards/SABERTOOTH_X79/HelpDesk_Download/
- pick OS windows 8.1 64bit
- Expand UTILITIES
- the first one is the latest version of Ai Suit 2 and you can even notice that Fan Expert isnt there.
thanks for the help!
yeah thats pretty weird, i mean i guess its different for every mobo, mine is sabertooth x79,
I downloaded 3 times now and fan expert isnt there.... you can see it here:
http://www.asus.com/us/Motherboards/SABERTOOTH_X79/Help...
- Expand UTILITIES
youre right it is, ill keep you updated, but doing this wont mess my mobo up or anything right?
So after a lot of messing around with the Ai suit 2 software, i noticed that the Fan Expert for this mother board is called Thermal Radar....works a little differently and in my opinion not as effectively but thats it. At least my fan i think are now a little more quite.....thansk all for the help and time!
