SEEKING A VERY SPECIAL PSU:
Instead of having to hardwire a 700W DC to AC power inverter into my vehicle's electrical system and then plug-in the PSU for my ATX sized PC into that, has ANY company come up with a special PSU that can be direct wired into a vehicle's 12VDC system and therefore eliminate the power inverter altogether???
It seems like a huge waste to go from DC to AC and then back to DC for the PC to use. Plus, the power inverter has a loud fan running when it is converting that much wattage. I believe that a PSU supplies DC voltages of only 12, 5, and 3.3, right?
OR, is there a documented way to "hack" an ATX PSU such that it can be fed 12VDC directly from the vehicle's electrical system? And, it would safely get enough current since it would be hardwired into the vehicle's 12VDC system (ie via proper gauge wiring). This means NOT giving it 12VDC from something wimpy like a cigarette lighter jack.
Thanks for any advice.
