AVISynth filters for VHS Noise Reduction and Sharping
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I have the VHS. The VHS quality is actually really good. What I'd like to do
is to remove those blue colored noises and then sharpen the image a bit.
So can anyone who has done, recommend me external filters and settings they
use? Thanks.
--Leonid
Leonid Makarovsky <venom@cs.bu.edu> wrote:
: I have the VHS. The VHS quality is actually really good. What I'd like to do
: is to remove those blue colored noises and then sharpen the image a bit.
: So can anyone who has done, recommend me external filters and settings they
: use? Thanks.
: --Leonid
PS. This VHS is PAL if it matters.
--Leonid
On 13 Dec 2004 17:48:27 GMT, Leonid Makarovsky <venom@cs.bu.edu>
"Blue colored noises?"
Neil Nadelman arvy@navzr-genafyngbe.pbz (ROT13)
I have no fears in life,
for I have already survived Theta-G!
You know the bluish artifacts.
--Leonid
Neil Nadelman <arvy@navzr-genafyngbe.pbz (rot13)> wrote:
: On 13 Dec 2004 17:48:27 GMT, Leonid Makarovsky <venom@cs.bu.edu>
: wrote:
: >I have the VHS. The VHS quality is actually really good. What I'd like to do
: >is to remove those blue colored noises and then sharpen the image a bit.
: "Blue colored noises?"
: Neil Nadelman arvy@navzr-genafyngbe.pbz (ROT13)
: I have no fears in life,
: for I have already survived Theta-G!
On 15 Dec 2004 21:21:55 GMT, Leonid Makarovsky <venom@csa2.bu.edu>
Actually, I don't. Can you post an image to illustrate them?
: On 15 Dec 2004 21:21:55 GMT, Leonid Makarovsky <venom@csa2.bu.edu>
: wrote:
: >You know the bluish artifacts.
I'll try this evening...
--Leonid
: Actually, I don't. Can you post an image to illustrate them?
This image is taken from MPEG-2 file. On computer it looks somewhat ok: dark,
but on TV screen it looks like a mixture of blue and green colors.
http://us.geocities.com/leonid_makarovsky/Temp/bluenoise.JPG
Do you want me to boost the brightness up and repost it if you can't see?
--Leonid
On 21 Dec 2004 17:37:18 GMT, Leonid Makarovsky <venom@csa3.bu.edu>
Looks like what you need is a "Chroma Noise reduction" filter. For
instance, the Cnr2 one at http://ziquash.chez.tiscali.fr, from MarcFD.
Thank you.
--Leonid
Bariloche <bariloche@bariloche.com> wrote:
: On 21 Dec 2004 17:37:18 GMT, Leonid Makarovsky <venom@csa3.bu.edu>
: wrote:
: >on TV screen it looks like a mixture of blue and green colors.
: Looks like what you need is a "Chroma Noise reduction" filter. For
: instance, the Cnr2 one at http://ziquash.chez.tiscali.fr, from MarcFD.
Bariloche,
does this filter blur the image? I am not experienced with chroma noise
reduction filters at all. Is the one you recommend the best out there?
--Leonid
> Bariloche,
I think that one (2.4?) has problems. You need the latest 2.61:
http://forum.doom9.org/showthread.php?s=&threadid=78905
Wilbert
