Agreed, we want to remove heat from the cpu.
Using ~ room temp water to do this will keep your cpu at 30-35 degrees as you are finding - and it sounds like a great way of doing it - do you get any system noise from the pump or anything to achieve this? If not, then you have one over on us aircooling people!
However, what if you want to get your system cooler? Okay, you may run into condensation problems, but that is a feature. Lagging and proofing will circumvent that in most cases.
<<If you pump ice water at 250GPH through the cooling block, it will be so cold & moving so fast, that it will pick up very little heat>>
In the case of air, why does a delta fan moving ait at 68cfm cool a heatsink faster and better than one that moves it at 30cfm? The faster the air moves, the more air that is exposed, therefore the greater the delta between the heatsink temperature and the air temperature.
If you have lots of water moving quickly, it might only rise in temp 1 dgree, but that means you only have to cool it 1 degree at the radiator too. If you allow the water to heat 10 degrees, you then need to cool it 10 degrees as well, which presumeably is harder.
I think there is a balance of water temperature, cpu temperature and flow rates. You might find that you are on the low end for this.
-* This Space For Rent *-
email for application details
