ax 1200i enough for 4way gtx 680 classified sli
xw1ck
23
Hi Forum Im wondering if ax 1200i will be enough for 4 way gtx 680 classified sli, 2400 mhz ddr3 ram, corsair h110, Asus rampage maximus iv extreme, i7 4770k OC to 4,6gz, and also graphic card oc, 2tb harddrive, x2 128gb ssds.
or should i get the Enermax 1500 watt they are both Platinum psus but diffrent watts i know 1500 watt is overkill but will the ax 1200i be enough, ALL HELP IS WELCOME NO DUMB ANSWERS.
Thank you all so much for helping 😀
