Hi,
My ax 750 makes a buzzing sound on idle, low loads and high loads, I have been gaming quite a bit approximately 5 months and it seems fine it runs cold, I have tightened the screws up, held it down lightly to see if it was vibrations to no avail, it isn't the fan either, it has been buzzing since i've put it into my pc. I have little to no money so buying another supply is out of the question. I can't RMA the supply as it has run out.
The buzzing has been the same volume on all loads doesn't get louder or quieter, the buzzing is really quiet it's only audible when you get about 3 inches from the supply. sometimes the pc won't power on, i'll hit the power button go to the supply and there's this flapping sound of electric so i flick the switch to stop power running through it and turn it back on and it'll power on as normal. the flapping is like a louder (By louder i mean a few dB higher not much) version of the buzzing but sounding different
Specs:
M5A99FXPRO R2.0
FX 8350
GTX 660
Corsair vengeance 16GB 4X4 1600 MHZ
And the buzzy ax 750
Will it be alright to continue using it?
Thanks
Specs:
M5A99FXPRO R2.0
FX 8350
GTX 660
Thanks
